Eric G
I've got a 36v2a sla charger that I use for opportunity charging on the road.Well over the years it's been banged about some and about a week ago it stopped working.I noticed that the wire going from the charger to the batts was worn out from constant use at where it enters the charger (bent back and forth one too many times).The charger box was glued together so I used a dremel tool to cut open the case.I cut out the damaged wire and soldered in a new one then Duct taped the case together again.It now works ....sort of!
The problem now is when charging It'll stop in the middle of the charge at ~ 39v and go from red to green and it just hangs there.If I disconnect the batteries and unplug from the wall and then reconnect it all and start again it will proceed until the charge is finished to 43.6v then go to float until the current drops to zero.
Any Ideas on how to remedy this would be appreciated.
Thanks in advance
Eric
Thanks in advance
Eric
