I have a small battery pack of three 18650 batteries in series to get 12V. I need to make a charger for it, where the materials I have are an adjustable DC power source (3V to 18V) with a port of up to 5A and a 3S BMS. The idea is to make a system to make it a CC-CV charger so in order to get a constant current charging of around 0.5C, I thought of using this charging board (https://www.aliexpress.com/item/32711173698.html). Is there anything else I might need in my system in order to get a correct charging of my battery?
I will be using a multitester to verify that I have the correct values in each input/output in the system. So in the end, my system would be: Adjustable DC power source to charging board to BMS to batteries.
Is there anything I could be missing or something that could be wrong? Also important, I want to do some testings on this battery pack so I want to be able to adjust different values such as the constant charging current and such. Money is kind of an issue here and it'd be nice to be able to use materials I already have instead of having to buy a bunch of new stuff or a ready-to-use charger that could be pricey.
