Hi there,
i am reading quite a long time in this forum and i think it is relly great. A lot of useful information for anyone qho want to build his own ebike.
Actually i am using a 27s LiPo for my bike. The cells only have 4 AH and i am charging the cells with a common 6s LiPo charger one after another. So i have to go every hour to the charger and connect the next battery.
The target is to charge the battery pack without disconnecting and connecting it every hour. The charging time ist not very important, so overnight charging is ok.
I see 3 possible ways to charge the pack:
1. Using a 4x 6s charger like this one and install 4 separate 12 volt power supplys beacause of the common ground.
http://www.hobbyking.com/hobbyking/store/__56173__Turnigy_4x6S_400W_Lithium_Polymer_Battery_Charger_EU_Warehouse_.html
2. Using a 27s charger with 113,4 volt like this one.
http://de.aliexpress.com/item/lithium-lipo-battery-charger-e-scooter-chargers-27s-li-on-chargers-113-4v-5a-with-fan/32320350292.html?ws_ab_test=searchweb201556_2_79_78_77_91_80,searchweb201644_5,searchweb201560_9
In this solution i have to balance the packe with 5 Balancing units like this:
http://www.hobbyking.com/hobbyking/store/__10328__HobbyKing_8482_Battery_Medic_System_2S_6S_.html
3. Using a Radiolink CB-86 Plus charger that charges one pack afer another even when they are connected in serial
http://orlandoshop.info/radiolink-cb86-plus-6a-210w-lipo-balance-charger-discharger/
Have anyone ever tried to charge a serial connected pack with this charger? The manufacturer says that the charger can NOT charge a battery pack that is connected in serial, but i geuss they dont understood the question.
What do you think which way is good to charge the battery pack, when you can charge overnight and dont want to check the pack every hour or two?
Thank you very much for your replies.
Best regards
Jens Bultmann
Best regards
Jens Bultmann
