torker
No not an EV but electrical in nature anyway. I have a 95 Geo Metro,bought for my son to drive and it has stopped charging. I have changed the alternator and it still won't charge. After checking continuity on grounds and between the alt. and pos. cable at battery and making sure I have key on voltage at the plug on the alt. for excitation I am stumped. I took the new alt. off again and took it back to get checked just in case it died right away but it checks good. One strange thing is that the battery light does not come on. It comes on with the key on and then goes out as soon as you start it. The book shows hot going to the light and then to the other term on the alt. connector When I check with the key on I have 12 v at both term. of this connector, there is 3 term.on the conn. and alt but only 2 wires not sure about the third.
Like I said I am stumped. I can charge the batt. to 13.2 it settles back to 12.7 it starts and runs the car fine but drops to 12v right after starting. Also this car has auto headlights and when you plug in the alt with the key on a relay shuts the headlights off till you start it. Seems normal. I've also pulled every fuse and relay except FI and IGN. and started it. Thinking something was drawing major amps.. Sorry so long.
Anybody got any ideas for me I want this rig on the road again..
