Lightfeet
100 µW
I came across a cheap pouch cell that Victpower is selling: NEC 72215265 35ah 3.7v 10c, 288mm x 218mm x 7.5mm , 800g, US 13.82$/piece, It would be good for a motorcycle application I wonder if it's good quality?
Lightfeet said:I came across a cheap pouch cell that Victpower is selling: NEC 72215265 35ah 3.7v 10c, 288mm x 218mm x 7.5mm , 800g, US 13.82$/piece, It would be good for a motorcycle application I wonder if it's good quality?
liveforphysics said:When MFG's have defective pouch cells, they slice the tabs off before giving them to the recycling company.
Victpower seems to once again have tapped a recycling waste stream, cut into the pouch tab exit area to gain access to the cut-off stub of tab, and then welded there own tab extensions on.
ARod1993 said:liveforphysics said:When MFG's have defective pouch cells, they slice the tabs off before giving them to the recycling company.
That explains a lot; those prices are cheaper than crappy SLAs, but if you're acquiring them at bottom-of-the-Chinese-barrel prices you can still make money. Just out of curiosity, the last time Victpower did this were the cells any good?
liveforphysics said:ARod1993 said:liveforphysics said:When MFG's have defective pouch cells, they slice the tabs off before giving them to the recycling company.
We know the previous batch they had was from the recalled defectively manufactured Fiskar Karma battery modules A123 shipped to China for recycling, then went bankrupt and never paid the recyclers, so they sold the cells to resellers instead of recycling them. This included tons of batteries that had sat for extended periods at <2V that they simply charged up and shipped to customers.
Personally, that's not a supplier I would want to support, and I wouldn't use the cells if they were free, but everyone has different goals and objectives and expectations.
John, Are you talking about the 35Ah cells? did you purchased some? How are they working for you?I got lucky with my shipment from victpower, all full tabs and not a dud in the 48 cells I kept! Unless you consider 18ah from a 20ah cells duds like a123 did.
