wturber
This charger was only ever intended to be used temporarily and/or as a backup. I had such good luck using a MeanWell LED driver that my intention was to get one for the new bike and new 48v batteries. Nonetheless, if I can keep this charger from becoming e-junk, I'd like to do that.
The charger was working fine until last night. It was charging a 35% full battery in a 93 degree garage when I left it. When I checked about an hour later, it was no longer charging. It is putting out the correct voltage, but the current output is measuring at slightly over 9 amps - and it is a 4 amp charger. Before I understood what was going on, I had blown the internal 5 amp input protection fuse on my three batteries. This is supposed to be a constant voltage and constant current charger. Even if I had a use for a 9 amp charger, I wouldn't trust running this at twice its rated output. So I'd like to fix it if for no other reason than I hate seeing stuff junked needlessly. Any thoughts on the most likely thing to have gone wrong? Ideas on ducks to shoot?
UY240 Series Battery Charger【价格 生产厂家 厂家】-Guangzhou yunyang electronic technology co., LTD
UY240SeriesBatteryChargerGuangzhou yunyang electronic technology co., LTD为你详细介绍UY240SeriesBatteryCharger的内容,包括UY240SeriesBatteryCharger的用途、型号、范围、图片、评论等,在这里你可以得知所有UY240SeriesBatteryCharger的新闻以及目前的市场UY240SeriesBatteryCharger价格,UY240SeriesBatteryCharger所属产品分类是Universal Battery...
en.gdyunyang.cn
