- Joined
- Jul 31, 2012
- Messages
- 61
Hi
For a long while, people have looked for options that are powerful and cheap for e-bikes ; a respectful bike in 2015 doesn't use lead-acid as there are good options for cheap lithium that are easy to set up. Buying cells that come from cars seems a good option (if you can find them ; they should become more and more accessible) and, having gone trough building a konion pack (learned a lot, but 20s/14p took me months) and having tested cells one per one, this looks easier ; quality of the cells is warrantied by conservative BMS settings (for the chevy volt). You can find some salvage cars for cheap in the usa, get the batts out and re-sell the parts to cover the cost .
A complete chevy volt pack is a T-shaped, 435#ish pack inside a fiberglass box ; one can easily remove the top and separate it in 3 blocks to transport in a car (all in an hour's time), and once it is skimmed of it's unneeded parts, you can lift them manually. Once home, you can separate it and have 12s and 6s packs just by unbolting. 12s (to upgrade 4 acid-lead 48v) and 18s (to upgrade 5 acid-lead 60v) 45Ah can easily be made. Nissan leaf modules look easier to work with but it's definitely not hard to work with chevy volt ones either ; plus, the cells are mounted on a liquid cooling/heating system (Québec winters need a heating system ; arduino+liquid pumps+DS18b20 = temperature monitoring and not far from temperature controll).
BUT, they don't have as much info on them as konions or hobbyking lipos : the ES community hasn't played enough with them yet I'm a curious noob, I have some questions, hence this thread to make sure I'm using them safely and don't end up burning my appt. Also, there are some contradictory infos on them...
Some threads already exist (http://www.diyelectriccar.com/forums/showthread.php/2012-chevy-volt-battery-93101.html), this one is about charging and ballancing 12s/18s packs
The challenge:
I want to design a suitable system to charge, ballance and monitor (for LVC) and stop discharge when at LVC. The less expensive, the better... but not sacrificing quality and, more importantly, battery durability. For a couple of reasons, commercial BMS don't seem to cut it.
Chemistry:
Hybridautocenter says they are LiMn2O4/LiNiO2 (no cobalt), other sources, like DocBass and http://batteryuniversity.com/learn/article/types_of_lithium_ion says it's NMC ; I don't know how having cobalt it will affect charging/discharging/ballancing.
Charging method
Charging a 45Ah pack will need a beefy p.supply, and most BMSs limit charge to max 10-15Ah... and the best commercial option without blowing the bank I found is 15Ah (greentime) ; 48v meanwells / server p.supply + Fechter's Mini Meanwell Limiter V.3 seem the way to go.
What would be maximum suitable charging C rate?
Ballancing method
dnmun told me (pm) "you will need a large balancing network since the cells are large" ; if I understand well, larger cells need larger resistors to drain more amps individually in case of pack imballance.
would a mod like http://endless-sphere.com/forums/viewtopic.php?f=14&t=31313 achaive that?
Konion cells (li-manganese) almost dont need constant ballancing ; how does it apply on chevy volt chemistry... is ballancing all the time necessary?
Has anyone used HobbyKing Battery Medics to ballance while charging? What about operation (discharge to ctrl, not discharge mode on battery medic)?
BMS plugs
each module (12s and 6s) has BMS plugs, worst case scenario, I could weld / glue ballance wires
does anyone have the pinout? does anyone know where to buy those plugs?
Thanks
Guillaume
The challenge:
Chemistry:
Charging method
Ballancing method
BMS plugs
Thanks
Guillaume
