Hi
The challenge:
I want to design a suitable system to charge, ballance and monitor (for LVC) and stop discharge when at LVC. The less expensive, the better... but not sacrificing quality and, more importantly, battery durability. For a couple of reasons, commercial BMS don't seem to cut it.
charge system (guru advice needed)
project A (tricycle) : 90Ah12s (2p12s3p) on a 48v/"500w" lead-acid upgrade
Direct DC to battery with meanwells and original lead-acid plug & wires or HP ESP120 input 220VAC output 49vDC [AC input from : http://www.tucsonev.com/ 240VAC plug] ; could it be 2x HP ESP120, one set for 46v and the other set for 49v to have a chademo-like charge curve (higher amperage for first 70% charge)?
project B (scooter) : 45Ah/18s on a 60v/"500w" lead-acid upgrade
direct DC to battery with meanwells and original lead-acid plug & wires
ballance system for both : http://www.hobbyking.com/hobbyking/store/__10328__HobbyKing_8482_Battery_Medic_System_2S_6S_.html when in use ; 2x imax b6 ballance @4,1v once in awhile
Chemistry:
Hybridautocenter says they are LiMn2O4/LiNiO2 (no cobalt), other sources, like DocBass and http://batteryuniversity.com/learn/article/types_of_lithium_ion says it's NMC ; I don't know how having cobalt it will affect charging/discharging/ballancing.
How will having more cobalt impact the rest? Charging, ballance and discharge [guru advice appreciated]
Charging method
What would be maximum suitable charging C rate? unresolved...
Ballancing method
chevy volt doesn't need constant ballancing, nor even constant checking
; ballancing with batterymedic or iMax B6/iCharger_4010DUO once in a while is neat but not needed every day (once a week to make sure).
BMS plugs
anyone can confirm http://www.digikey.ca/product-search/en?x=0&y=0&lang=en&site=ca&KeyWords=0015247180 fits? http://www.diyelectriccar.com/forums/showthread.php/wtb-bms-harness-chevy-volt-126010.html ...
Thanks
Guillaume
