Just managed to pick up this Quazzar e-divine retro scooter for cheap without battery pack. I believe it was manufactured by Ecobit back in 2015 and looks identical to any number of retro Vespa inspired scooter that have been around a number of years.
It originally ran off dual 60v 20ah removable packs - I’ve managed to run it OK with a single 60v 20ah pack. It’s not the quickest of things so I will be looking at upgrading the controller at some point (most likely Sabvoton).
Until then I have a 72v 40ah pack I’d like to use to increase range but I’m not sure the controller can cope with this when fully charged. It’s branded UGBest (same as original battery packs) and the label on it states 72v 45a output. It looks like a generic controller with form factor similar to a Votol.
The step down converter for 12v system can cope with up to 100v so really just trying to get a sense from folks here what you think the likelihood is that I can run 72v (84v fully charged) through the controller without blowing any FETs or caps?
I know to be certain I should take controller apart to identify specific caps and FETs to see what they can handle ... just working out if I risk it and connect my 72v pack given I will replace the controller eventually anyway.
