I bought at my canadian tire store this product go take a look : http://www.corrosionfree.com/automotive.htm
its :
USES
Electrical
Electric motors, starters, generators, alternators, switches, terminals, rheostats, circuit panels, ignition systems, light sockets and any electrical point of contact.
Mechanical
Pre-assembled metal parts, winches, pulleys, bearings, shafts, bushings, hinges, cables, aluminum wheels, steel rims steel or aluminum castings and anything that moves.
Appearance / Detailing
Doors, trunk lids, engine hoods, lapped seams and joints, nuts, bolts, chrome and aluminum accessories, and basically anything requiring protection from the elements.
BENEFITS
* Terminates rust and corrosion in all metals
* Clean, clear, DRIPFREE - no sticky residue
* Dissolves and neutralizes existing rust and corrosion
* Penetrates the start of new corrosion
* Protects paint from blistering at edge of lapped seams
* Stops electrolysis between dissimilar metals
* Protects UnderBody including brake and fuel lines
* Penetrates deeply and lubricates
* Repels salt water and moisture
* Will not wash off with water
* Heavy Duty gel formula for extended protection
METHOD OF APPLICATION
* Formulated to be applied under high pressure to hidden areas using the CorFREE applicating system, or brushed / wiped on to exposed panels
* Can be applied to wet areas
* Apply every 18 months or annually as required
SPECIFICATIONS
* A proprietary blend of lubricants, moisture displacers, corrosion neutralizers and inhibitors
* Solvent-free - Odor-free - Non Toxic - Non Conductive - Di-electric 40,000 volts
* Non Flammable as a liquid - Low Fire Hazard - High Flashpoint
* Not a controlled substance - not subject to TCSA - not controlled by WHMIS
* Specific Gravity .86 - Boiling Point 260 C - Negligible solubility in water
* Non Carcinogenic - Light Green Color
