Hi
I have a crystalyte hs3540 running 48x60A Lyen 18FET 4110 and have replaced hall sensirs before after motor turned out of axle and pulled all wires etc. (that was when i had Lyen 9FET and 48x30a)
Running regen and at 60A the motor locked up down a long steep hill as the phase wires melted to stator.
I upgraded the wires to turnigy silicone 12AWG AND ALL SEEMED FINE. until i got a flat and removed wheel and repaired.
Now the motor runs for a few minutes and then shudders which makes me back off the throttle and coast or only light throttle for a bit and then i can full throttle again before it starts to shudder again.
It is like a phase problem as halls are a different feeling through the bike.
I have pulled motor apart 3 more times and cannot find the problem.
Ive done continuity test of phase wires. From controller to motor. And diode check of controller which had the following results
Black probe to red power and red probe to phase exit controller
green 417
yellow 419
blue 427
Red probe to black power on controller and black probe to phase exit controller
green 424
yellow 424
blue 421
I even checked to see if windings were touching the metal lip of inside stator.
Has anyone ever had this come and go shudder which seens to be a heat related problem???
green 417
yellow 419
blue 427
green 424
yellow 424
blue 421
