Trevor Loughlin said:
It could be made of titanium tubes stressed with internal carbon or boron fibre braces, but if it reused all its structure and motors in a different configuration the only additional weight would be the sail material, which could be thin plastic,nylon or silk perhaps strengthened with steel wire.
A bike that transformed into a tent would be a good idea as well!
Hi Trevor...
You used the S word - sail... A vertical air foil or a kite would serve (more efficiently) to harvest wind energy under way... as a power-assist to your power-assist... a tribrid.
If you have access to moving water as waves or stream, water has about 800 times the density of air, so moving at the same speed there is potentially a lot more energy to harvest from the water...
There are different ideas for turbines in streams:
http://www.rosneath.com.au/ipc6/ch08/shannon/
... but if you are on the Channel then wave action might be constant? Or at least, the wakes from all that marine traffic <wink>
Tidal races, see turbines/wheels above... but wave action, the one I like drops a pipe 1/2 in the water, and the column of water in the pipe rises/falls w/each wave. The air column in the pipe above water level then "breathes" too, as it is forced up/down, and this breathing spins a turbine...
keeps the electrics/turbine out of direct (saltwater) immersion.
Big scale example here:
http://www.irishscientist.ie/p186a.htm
All air props suffer from more "slip" than in water, so again, if you have moving water around, consider that first!
What sort of generation system you need depends on your energy needs (how much and how often) verses what is available from the ambient, and how efficiently you can generate and store same...
It takes quite a bit of energy for traction/transport... Food energy, electrical, whatever...
Don't overlook regen either, if you are up/down or stop/go. The one runs on free energy (gravity), the other recaptures what is otherwise wasted.
G'Luck
Lock
from the colonies
