kiradieskira
- Joined
- Jul 19, 2020
- Messages
- 10
hi.
i have a Vilano Atom Ebike. After a rainy day, I started getting error 30 on the King Meter display. Through process of elimination I thought the controller to be the issue, in the meantime I ordered a throttle (it hadnt had one), and a bundle controller and display, Brainpower S866. It finally came , I pieced it together, nothing, no command to the motor at all, than after a bit, I get a ((!)) error, which is a communication error, same as error 30. The only thing that I can think of it to be now is the motor itself or the hall, but I had tested this on a friends scooter. It did run, but he said the the movements were kind of jerky, like it didn't know which way to go. It is a direct drive motor.
I saw somewhere that you can reprogram the controller to be sensorless? Is this true? I'm no good with a volt meter, yet.
Also, P07 is the only setting I didn't know the answer, speed magnets or total magnets in the motor? and how do I find out how many magnets are in my motor? Hopefully, Maybe a correct programming will get rid of the communication error? Also, on the new controller there is an additional 3 wire connection. the white, black and grey one. It this a necessity?
Either I am missing something completely, Or I am doing something wrong. And I'll take any help I can get.
Thanks so much!!!
Old Controller, New Controller:
Thanks so much!!!
