adrian_sm
Thanks Richard. Did you mean to link to a specific product?
adrian_sm said:Thanks Richard. Did you mean to link to a specific product?
:wink:jonathanm said:Just subscribing to this thread....great!![]()
liveforphysics said:All sensorless drives (short of flux-vector type, which there are zero RC types that are able to do) just have to play a pre-defined series of pulses into the motor, called the starting algorythm, and hope they get rotor motion that generates BEMF that they controller can use to know rotor position. When this pre-defined series of pulses starts off, it's equally likely to be jerking the wheel backwards as it is forwards, but after that the average amount of jerks the rotor takes should be the desired direction of rotation. If the rotor doesn't rotate, then it has no way to know if it's applying torque in the right or wrong direction. If the rotor is stalled or not able to jerk into motion, then it has no way to continue to run the motor, and it just has to play the starting algorythm again and hope for the best. This is the nature of all sensorless controllers (excluding flux-vector drives).
So, this is how it gains sync to begin with, so it has an idea of rotor position to know which coil to energize next to continue making torque in the desired direction.
