dirkdiggler
- Joined
- Oct 17, 2012
- Messages
- 641
I usually am in the skateboard/scooter forum, but since building my first ebikes I've been hanging out here in the mid-drive area. As there isn't much crossover between the two areas member wise, I am curious as to the major differences between the controllers used for ebikes and those for RC or scooters/skateboards. I don't know too much about the electronics, I'm learning slowly. My main question would be how is it that the controllers have such a huge difference in size and capabilities. The RC ESC's that we are using for skateboards top out at 24volts or 6s (You can go 12s for more money), but are able to handle around 150 amps. My controller on the BBS-02 maxes out at 25 amps, but uses 48 volts. The BBS-02 is much smaller than say a hub-drive controller, but is still huge compared to the RC ESC. From what I've read here (the non-hub motor drive forum), the RC ESCs are way over rated amperage wise - but in reality on my wattmeter using my eskateboard , the amperage seems to check out. I've pulled at least 80 amps on a 90a rated esc and it still functions fine. No smoke or fire. The ESC doesn't run hot at all using 1000 watts. Thats 24 volts times 50 amps. Same watts as the BBS-02. The RC ESC lacks some of the functionality of the ebike controllers, with brakes and wired throttle control. That is easily fixed with a servo tester though.
As space is limited on bikes as much as on a skateboard, why are not more people using the RC ESC on a bike setup?
Cost also seems to be a factor in the RC ESC favor with a 2000w bike controller being well over a hundred dollars and the RC ESC costing $50?
Any major disadvantage to using a 24v system with higher amps if the ESC can handle it?
Any help describing the differences in what's under the hood comparatively?
