Configurable external 22S+ BMS
hias9
I am looking for a solution like a 24S BMS (at least 22S) that will only be used for safety when quick charging at home without using a balance charger. It will not be on the bike, so size is not that important.
While charging, my lipos will be wired 22S and the BMS can be connected to the balancer wires.
It should be able to take at least 120amps continous charging current and should cut off if a cells reaches a critical voltage (for example 4.3V). This voltage should be configurable.
Cell balancing would be nice, but is not required. A possibility to view cell voltages (on a display or via bluetooth) would also be nice.
