ebike_rocket
- Joined
- Jun 16, 2011
- Messages
- 28
Hi everyone,
I'm working on my second ebike build. It's a 36 volt system, 500 watts. I have three SLA batteries rated at 12 volts, 17AH each wired in series, with positives going to negatives. I have an ebay bought conversion kit. The kit is rated at 36 volts, and again 500 watts. When I first installed the kit, the batteries were undercharged, and I didn't get any sparkz shorting out between the connector, which is a computer cable wired to a two slot connector into the controller. But, now, after fully recharging my batteries with a smart charger, every time I connect the computer cable, it shorts out, leaving carbon on the make end on the negative side, and melting rubber and plastic, and probably leaving carbon on the female side. The fuse which is a 30 amp fuse, is located on the negative cable. I used a multimeter to check the voltage of the total bank, and it's 38 volts.
What can I do to stop the shorting out of the cables? I thought at first it was a short circuit in the cable, but checking the cables show no such thing. I find it interesting that the short constantly happens at the computer cable attachment. The computer cable attachment is the same thing that you'd find in the back of your computer, a three prong connection. There's no ground wire on the system, and like I said, I didn't have this problem when the battery bank was under charged.
Is there a safety circuit I can construct to ensure the voltages are always at 36 volts, is it because the batteries show up as 38 and the system is 36, or am I missing something?
