Hi guys
Im having a problem with my KU93 controller. The shunt is modified to 25-28A or so for more torque.
I have a lower coded ,high rpm Bafang 8fun geared rear motor and battery is about 59V or so after a full charge.
At first I was melting the butt connectors from the heat but even with different connectors, the heat is still melting the wire coating and onto other smaller wires as well.
Would any of you have a heat solution that worked well for you ?
Thanks!!!
Thanks!!!
