jkrienert
⚡ Regular
- Joined
- Jun 13, 2021
- Messages
- 312
Hello!
I'm working on isolating the HV of a Numi (tm ?) 840 scooter, rear-driven by a 1500w constant 72v 3-phase hub. It originally had a to 12v Dc/dc with common ground (frame) to the battery 72v-. I opened its generic manuf. BLDC controller rated at 72v 40A batt. max to check isolation there. It also utilizes a 72v- common ground for the 12v accessories (turn signals, lights, etc), and 5v controls (instrument panel, throttle).
I've already redesigned the battery (+fused 73.6vNom 32s2p LTO with O.G. Orion BMS) with contactors, and swapped the common Dc/dc for one that is galvanically isolated. I use a 12v accessory supply (power tool battery) to soft (resistor) open the contactors to power the Dcdc and controller. The 12v system incorporates a HVIL with several safeties (inertia switch, service door switch, kickstand switch).
Can the controller also be (galvanically) isolated? Is an isolated controller superfluous since the HV traction pack is already isolated? I mainly worry about shock hazards and negative impacts to sensitive components if any ground loops would emerge... Maybe some other wiring aspects I could consider or evaluate?
Can providephotos or more description if needed. Thanks.
SEE photos of controller here:
endless-sphere.com
EDITED: For simplicity.
EDITED AGAIN: To link photos of controller.
Can provide
48-72 Regen capable 48-72v controller?
Does the controller shown in the attached images support Regen? This unit was originally installed on a Numi Elite Quadhopper 840 that was manufactured in 2015. I bought this EV used in a debilitated state (dead SLA). This vehicles weight and aero, along with the hilly terrain it will be used...
endless-sphere.com
