Thank you so much;
for detail explaiantion and the photo; I will try to do wd 40 today.
Regarding to reply please see capitals below;
2. The sound issue. Following questions to you:
When do the tack tack sound appear? Only when the motor is working? YES WITHOUT ASSIST; NO TACK TACK SOUND If so, is it getting louder when you put more power to the motor?
YES IT START 1 DAY OF EVERY THREE; AND AFTER I GIVE POWER IS TACK CTACKS BUT WHEN I REDUCE A LITTLE SOUND MAY GO OFF;
ACTUALLY SOUND INCREASE SINCE LAST 400 KM ; BUT WHEN HAPPENS ITS COMING OUT MORE LOUD THEN BEFORE..
Is this sound in synchronicity with your pedaling? ı THINK ITS NOT SYNCRONISED WITH PEDAL; ONCE I TRIED TO MAKE RYTM TO UNDERSTAN IF ITS COMING CONSTANT PLACE WHERE MY PEDAL IS BUT NO; DUE TO CRANK REDUCTION ITS NOT POSSIBLE TO UNDERSTAND .Is it quiet when you are just pedaling without motor? YES Give us as much details as possible, because it is very difficult to locate the origin of the sound.
First try to spray some lubrication like WD40 into the freewheel of the 3rd transmission stage. Perhaps it helps. THANK YOU I LL TRY THIS TONIGHT; BUT I LL LET YOU KNOW IN A ONE OR TWO WEEK DUE TO MU SOUND ISSUE NOT COMING ALL THE TIME.. THIS IS THE MOST BOTHERING ISSUE; bECAUSE I GO MIN 40 KM EACH TIME; AND IT MORE PSSES ME AFTER START OF 15 KM ..
Unfortunately you cannot disassemble the freewheel without special tools. I KNOW MY COMPANY HAS A TOOL SHOP; PRODUCE INJECTION MOLDS AND AUTOMATION MACHINES BUT OUR EXPERTS EVEN SCARED TO CHECK IT
Read my story: After 500 km I had a fatal damage of the bearings in the third transmission stage. One bearing was totally destroyed. The mechanician of my bike dealer told me that the bearings are of asian manufacturing. I think it is the wrong way by Conway to save some money for such an expensive bike. So the mechanician changed them to SKF bearings made in Germany. But then my tack tack issue began.
It was so difficult to locate, because everytime the mechanician put it apart and back together the sound was gone for around 30 kms. But came back then. He did this like 5 times and also changed all the bearings from the second transmission stage too. Clacking sound wasn´t gone.
I then was able to locate the sound. It definitely came from the third transmission stage. The sound disappeared shortly when he sprayed lube (I think WD40) into the freewheel of the third transmission stage. So he changed the freewheel. Although everything was changed except the shaft of the 3rd transmission stage the noise was still there. So he examined the shaft. It is made of eloxated aluminium and he discovered, that is has shrunken of some reason. He said the shaft should be made of steel because the power is very high in this transmission stage. Unfortunately the spare part was not on stock, so he shipped the whole bike to Conway in Hoya, Germany. I should get it back next week and I hope the clacking sound is gone forever.
YOUR STORY IS SO HELPFUL SIR; ı HOPE MY PROBLEM IS NOT THERE BECAUSE I AM IN TURKEY AND IT WOULD BE VERY HARD TO BRING BIKE BACK TO GERMANY
IN THIS PONT MAY I ASK A FAVOR ?
THE SERVICE YOU USE; CAN PROVIDE ME ALL TOOLS THAT BIKE NEEDED ? HE CAN JUST GIVE ME CODES OR I CAN BUY FROM HIM NO MATTER; SOME HOW ITS CLEAR THAT I LL HAVE TO GET THOSE TOOLS.
PS. THIS BIKE IS SO COOL; ı L BRING A FEW MORE FOR MY FRIENDS AND MY FAMILY. SO I NED TO BE FULLY EXPERT ON THIS THING
TAKE CARE SIR
BEST rEGARDS;
CAN
TAKE CARE SIR
BEST rEGARDS;
CAN
