John in CR said:
That still leaves you conducting the heat from the source through a layer of air to get to the outer shell then to the environment, not to mention that 100% of the electricity used by the pump motor gets turned into heat. A simple alternative, assuming there is clearance between the spinning cover and the non-moving internal parts of the motor, might be to put some fins, paddles, whatever, on the inside of the covers. The idea would be to create more air movement and turbulence inside the motor in order to get all of the internal parts including the air to the same temperature. That might get the covers to a higher temperature, which has to be the goal in order for an unchanged exterior to exchange more heat.
Heh. This is starting to remind me of Safe's "Ice Kissing" argument a while back.
Anyway, like I said, the gap would hopefully be really small (like a mm or less). An important aspect is that the windings are only around the edges of the sideplates. The middle is mostly hollow. Heatwise, they'd now be right next to them with 10X or more of the exposed surface area.
A few watts from a pump will maybe amount to all of 2% of the heat output at times.
I'd imagine most sideplates already stir up the air a fair bit. Even a flat surface can churn air pretty well, and all the sideplates I've seen have like six small radial fins on the inside for mechanical strength.
John in CR said:
Wouldn't increasing the axle size to say a 1-1.5"ID steel pipe be easier than putting a pump on the inside? Then just run your tubing to an outside pump and heat exchanger. Other than pressing the existing axle out of the hub, the most difficult part would seem to be the changes needed in the covers to fit the larger bearings required. Even if it proved more difficult, at least it would guarantee better heat exchange.
John
LOL, undoubtedly. But it'd kill the stealth factor a bit. Though I'd imagine it could also make a pretty cool sort of accessory (no pun initially intended). :wink:
vanilla ice said:
As long as you are feeding miniature copper tubing through the axle of a brushed hubby, could you not use the copper tubing as one of the two conductors to save room? Or even plumb two separate systems with insulated tubing, and use one for each polarity. I think very small tubing could still work well as long as the speed of the water flow is adjusted to suit the cooling needs.. Besides, we're not talking about 25 or 50 horse motors here.
I wouldn't wanna try it. Unless you went through some pretty painstaking procedures to completely insulate the copper from the motor, too, you'd turn the whole motor and bike frame live. The potential for a disastrous short goes way up.
And brushed hubbies aren't really the problem, since their windings are on the outside casing, like this:
And brushless ones have the coils on the inside stator, like this:
