So I been lurking for quite a while and I love Grinhill's design. So I would like to copy it.
So much has changed since December and Matt's amazing recumbent. I have been trying to catch up for the last couple weeks.
Grinhill you did an amazing job! http://endless-sphere.com/forums/viewtopic.php?f=28&t=9172
Since I finally have a few bucks to actually build something!!! Here is my parts list...
Motor - TGY AerodriveXp SK Series 50-65 270Kv / 2100W - should be easily upgraded ( see controller )
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=7709#
I have decided to go with the 63-64 instead. This way I have some wiggle room.
http://www.hobbycity.com/hobbycity/...TGY_AerodriveXp_SK_Series_63-64_230Kv_/_3150W
I will do preemptive CA glue and check the bearings. If they are not very good I will replace them.
Controlller - TURNIGY Sentilon100A HV 5-12S BESC (Ver4) - this should provide plenty of overhead.
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4691
Battery - ZIPPY Flightmax 5000mAh 6S1P 30C
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8590
What would be a decent charger to purchase for this battery?
Lower Pulley - The spoke-mounted pulley from Golden Eagle.
http://www.bikeengines.com/orderpage2.htm
Upper Pulley - no sprague clutch just attach pulley to motor. Have to drill out to 10mm.
https://sdp-si.com/eStore/PartDetail.asp?Opener=Group&PartID=59699&GroupID=346
Throttle current limiter.
http://endless-sphere.com/forums/viewtopic.php?f=28&t=8160
I got in on the first batch so I will be able to regulate power.
(edit removed obsolete information updated links, corrections)
Thanks everyone,
Joe
Thanks everyone,
Joe
