mrzed
Just moved to a new house, and now I have a 1/3 acre property with more grass than I can handle by dragging the 100' extension cord around. I do however have 116 tested makita cells from DrBass in the garage from my earlier plan on building myself an ebike battery that got long delayed (something about a toddler, a grade schooler and a full-time job I suspect). With the new big lawn, the ebike takes a back seat, because I have legs to pedal, and there's no way I'm burning gas to cut a lawn, I'd rather get a scythe.
I did find for $20 one of http://solarispowerproducts.com/index.htm. It's a 24v SLA mower with a brushless motor. I thought I was being clever, but now I'm concerned because the thing likely has a controller attached of some sort, so I'm a little concerned it may try to outsmart me if I mess with the voltage too much.
I can't find anything out about the actual specs of the thing online, but the nut of the issue is this:
- Go 7s and hope the higher voltage at full charge doesn't trip some error in the little brain attached to the motor
- Go 6s, but perhaps limit the depth of charge I can get because the LVC it uses for the SLA will be lower than what is reasonable for the makita cells
The brain is built right into the motor apparently. I'm assuming it has a circuit of some sort in there, because of the 4 wires coming out for the LED battery indicator, on/off switch, and the description on the unit of the error codes from the LED's.
