Zombiess,
11,258W output is 15.1 peak horsepower by my calculations.
On the subject of heat, you're making the all too common mistake of so directly linking it to efficiency. The motor makes the same amount of heat in the copper with the same phase current whether the motor is operating at high efficiency or low efficiency. Efficiency is a result, not a cause. Low efficiency doesn't cause heat, current does. There's no getting around low efficiency in the early stages of acceleration, since from a stop it always starts at 0%, and efficiency is low because rpm, and therefore power, is low. Forcing (actually trying to force) a 50% minimum efficiency would make for a horrible ride.
Regarding my controller settings, the current settings were almost the first ones I tried. FWIW, I probably run at a lower duty cycle that almost anyone. I rarely exceed half speed, but when I do get on the highway is when the controllers are the under the least stress, since the motor limits the current well below the programmed limits. Up thru mid 2010 I blew a tremendous number of controllers, but not a single one at high speed. That's where our systems are the happiest, and that's before considering the greater airflow to cool them. Exactly how much my current levels decrease at highway speeds compared to during the few seconds to get there is the kind of data I look forward to seeing with my Grin Tech Analogger plugged in. At this point I have only educated guesses of how much power I use to go 60 or 80 or 100mph.
You're right about the crazy climb to the top of the mountain, because I do need to be careful with the controllers. The one time I did it though I really attacked it, but slowed extremely for the curves, because I was totally unfamiliar with the road. I'd probably lower the settings next time, but even with higher settings I think I could make it easier on the controller than before simply by maintaining a steadier speed.
I've lost 30lbs, which slightly more than offsets the bigger load the motor sees due to the increase in tire size, so as I lose more I should be able to nudge the controllers up a bit. That's because I will ask for the higher current for shorter durations and/or BEMF will climb faster lowering current more quickly to better protect the controllers.
Doc,
Your analysis leaves out the impact of the Kv.
We're limited by voltage, so an otherwise identical motor with a higher Kv will always be capable of higher power. That's because different windings have identical torque limits (assuming equal copper fill of course), but the higher Kv motor can do it at proportionately higher rpm and power (assuming it hasn't reached it's rpm limit of course), since power = torque X rpm. A MXUS is less motor than a Cromotor, so unless you got the 3 turn version or you exceed 100V fresh off the charger, each one can't break 10hp. You're a light guy, so it should still be awesome power for you.
