crossbreak
127mm without cooling fins. 140 with fins. 150 with air duct. I will post a drawing tomorrow
static, like a hub. The revolt needs large bearings that have a lot of drag...and loss. They are also not durable enough for a chain/belt drive...the hub design fits our needs much better. I used 6302 bearings that have much higher Cn than the 169xx series bearings that are used in outrunner motors that where disgned for planes/ propeller drive in the first place. We discussed that on page 3 https://endless-sphere.com/forums/viewtopic.php?f=28&t=80516&p=1191703&hilit=bearing#p1191703sn0wchyld said:is it a static axle like a hub, or with a 'boltable' section like the revolt?
crossbreak said:I think my design skills are okay, but i have no idea how to make it even more narrow :/ ideas are welcome!!
Actually, the space is only needed near the axle. the side covers could be cone shaped to save some space in the outer region and to make it more rigid. Even a steep cone is more rigid than a plate.madin88 said:on the CAD it looks like there would be some space on the left side (between bearing and stator).
or is it necessary for wiring and sensors?
