How have you made your regen stronger than the next guy ? Something other than in the software ?Arlo1 said:I use hard regen
NeilP said:I do not see that a tight keyway...key being the width of the stator 14mm...and a 8mm deep key...4mmin stator...4mm in axle, is any more likely to move than the splined fixing.
John in CR said:Lowracer,
What is the yellow tape around the perimeter of the stator for? Just to protect it while you work on the motor?
Yeh thats it although im not saying your keyway is better or worse i think a taperlock or something would be better. I know the factory splines were nothing great. But a keyway will eventualy work back and forth from accel-deccel hits and as it works loose it will get worse at an acelerated rate.NeilP said:I do not think Arlo is having problesm with the axle..I think it is jsut he is worried that at keyed stator on the axle is not as strong as the factory splined fit.
docnjoj said:Yowser John! That is a big bearing. Why did you not consider having the torque arm come out of that central part of the hub?
otherDoc
LOWRACER said:Doctorbass said:Excellent!!!!
Lowracer.. You rock !!![]()
so that motor fit in the standard 135mm width?
How it can be lighter than the old 5300 since it have more copper, steel and aluminum !!!![]()
Doc
The heaviest part at the hub motor is definitve the rotor with magnets, it's complete steel!
That's good, because I've seen much motors where the spokes are frayed away. 8)
No, not exactly 135mm, exactly 150mm width!
BUT, I must admit that in a 5hours test run one of the china hall sensors is broken!![]()
I've got figured out, that the hall sensors, the ball bearings and the axle are cheap china trash!![]()
Now I change the 3 sensors against HONEYWELL SS40,
and I change the ball bearings against SKF 6004-2RS / SKF 6005-2RS,
and I change the axle against a new selfmade 12.9 STEEL AXLE with build-in torque support!
esoria said:LOWRACER said:Doctorbass said:Excellent!!!!
Doc
info please, the motor (150mm) can fit in the mtb bike standard 135mm without modification?
thanks
wojtek said:i wish i could smell the burning tyre while watching the video!![]()
Chris, any plans to eliminate the heating issue on this hub motor?
