I'm surprised nobody has brought up curb damage, ppl wanting custom rims, snow, salt, specialty machines to change tires. Do you know how often wheel speed sensors go bad for brakes, imagine hall sensors subjected to the same environments, not to mention the bazillion pounds of metal shavings on the roads at any given moment from the lack of maintenance on 90% of the vehicles on the road. Plus if you are unlucky enough to live in places like Baltimore or DC or NYC you would need new wheels/motors every other month. I think manufacturers understand the baha like roads that our cities are made of thus they shy away from hub motors.
Yes; the roads are bad. And if you think they're bad there, you should see them here! (The 'New' South Africa and Africa in general)
Now did you watch the video of the Bose Active Suspension sensing and jumping over bricks, potholes etc?
Did you see it retracting the wheel/s just the right amount and extending it again for it to go over the pothole with zero movement of the car body?
Now IF that active suspension is in the wheel, between the hub and the rim; then the hub motor with all its hall sensors and whatever is as still as the cart body in the video.
If you look at the 1st video;
the hub Motor does DOUBLE DUTY as both a motor AND a fully active suspension...
ie:
You can take the heavy suspension and shock in your bike, car, truck a
nd throw it away! Because you no longer need it! Its just dead weight..!
Also; if the hub of every wheel is now (better than) sprung weight,
then
you deduct the weight of the hub, brake disk, suspension arms from your unsprung weight and move it all over to sprung weight, where it doesn't need to be designed as heavy and large.
So what does that leave you in unsprung weight?
The outer rim and the tire.
How much does that weigh vs the unsprung weight of the status quo?
And what does reducing unsprung weight by 60-70% do for vehicle dynamics..??
So now its not just the
increased reliability of of the hub motors now being (better than) sprung.
That
nullifies the weight=power constrains that apply to unsprung hub motors..!
Its a
decrease sprung weight. (now better than sprung) and in a car; an increase in space and better aerodynamics.
And a
decrease in unsprung weight buy a LOT! Including the now big/powerful hub motor.
Which will do wonders for vehicle dynamics and road-holding..?
