kbarrett
OK ... tried a c'lyte cruise control. Neat gadget. kinda cheaply built. The cover on mine needs some polystyrene cement already, just from mounting it. Handle bar mount, but it won't open wide ... you have to pull your handlebar grip, shifter, and brakes off to slide it on ... bad design there.
Three buttons: +, -, and a bigger on/off button. And a red active light.
Button only activates if there is at least a small amount of throttle input.
No throttle = button won't light up.
Once it is on, the controller ignores the throttle input, and only uses the cruise control input. It stays at the speed of the last throttle position ... you hold in the + or the - buttons to alter speed. It goes off if you hit the e-brake, or hit the activate button again.
So , for this cruise control, you have to have some kind of throttle ( even a thumb switch will work ), and you probably want e-brakes.
( I'll post a photo once I get back to my camera tonight )
