CRYSTALYTE motor 5300 to 5400 Winding Electrical Information
Doctorbass
Quebec, Canada East
This thread is to sort all MEASURED caracteristic of the X5 motors
after all.. it's the most powerfull hub motor we can get for bicycle...!
Every time i dissassemble one i carefully measure and note everything about them that is under the cover.
( all with calibrated fluke equipment)
-number of pole:12
-number of magnets: 24
5302: 10x2T
--Kv: 18.2
--number of strands: 10
--size of each strands: AWG 20 ( 0.032"dia)
--All strands = to one 10 AWG
--inductance bewteen two phase wire: 79uH with my meterman XR37 and 109uH(retested with calibrated Agilent LCR meter) 5 jan 2014
--DC resistance between two phase wire: 0.045ohm (direct to winding)
5303: 8x3T
--Kv: 12.1
--number of strands: 8
--size of each strands: AWG 20 ( 0.033"dia)
--All strands = to one AWG 11 conductor
--inductance between two phase wire: 169uH with my meterman XR37 and 220uH(retested with calibrated Agilent LCR meter) 5 jan 2014
--DC resistance between two phase wire:0.097ohm(direct to winding) and 0.103ohm(thru the anderson connector)
5304: 5x4T
--Kv: 9.1
--number of strands: 5
5305: 4x5T
--Kv: 7.14
--number of strands: 4
--size of each strands: AWG 21 (0.029'")
--All strands = to one AWG 15 conductor
--DC resistance between two phase wire: 0.142ohm
5306: 4x6T
--Kv: 6.1
5403: 8x3T
-kV: close to 9.. but estimated only
--size of each strands: AWG 20 (0.032'")
--inductance between two phase wire: 297uH
--DC resistance between two phase wire: 0.104ohm
AWG reference is here:
http://www.powerstream.com/Wire_Size.htm
Some older 5305 reference are here:http://endless-sphere.com/forums/viewtopic.php?f=2&t=4404&hilit=parameter+5305
Hey doc,
You should change the pole count for x5303 to 14 poles.. unless .. i'm wrong :p
-steveo
steveo said:
Hey doc,
-steveo
Hey Steveo,
Thanks i 'll double check that but i've always thought that all X5 have 12 poles.. just like justin is suggesting on about the X5 motor serie?
If you have some more info to add to these informations please PM me them.. i'll add them.. also i wanna know about the 5306 if it's 4 strands of wire and what is the diameter of that wire on the winding ( measured)
Doc
Some typical pics of a X5 stator :
( here is a 5303 being converted to a 5303 and 5306!!)
... with some modification as well; 6x Relay, heat shring on the phase wire strands, all phase are splitted into two independent winding...
Update 1 april 2012:
Added: Crystalyte 5403 motor
Thread of the complete review and pics here:http://www.endless-sphere.com/forums/viewtopic.php?f=30&t=38300
ELECTRICAL PARAMETERS:
Phase to Phase DC resistance ( direct at the junction of the winding terminal and the phase wire so no phase wire resistance included)
Current: 10.0A, Voltage across phase to phase 1.042V Resistance = 104.2 miliohm
Inductance Phase to Phase ( measured across the phase wire wich change nothing to the inductance of the winding)
= 341mH
Some Update today ( 5 Jan 2015 ) on the inductance of the X5 motors ( 5302 and 5303)
Doc
Update: 7 Jan 2015:
Updated KV info of all X5300 serie
