stephen086 said:
yes its a crystalyte controller is this the wire in picture do i just plug it in and leave it plugged in ?
Will this reduce the performance of the motor cause its putting it in reverse ?
Yes, that is the one. The factory didn't label it, no one know about it. It will cause to reverse either plug or unplug the jumper.
I used Crystalyte sensorless controller to run other brand of motors, if the motor run backward, i simply use the jumper to correct it on the fly. The purpose of this jumper wire is exactly for this situation.
John in CR had a differ opinion, but I would put a CycleAnlyst to monitor amp load consumption to determine if there is performance problem, i would also combine it with RPM test to see if you get the same rpm on both direction.
One more statement that I like to make:
If you have a Crystalyte sensorless controller, and Crystalyte sensorless HS3540 motor, the phase wire color should be exact match: Green to Green, Yellow to Yellow, and Blue to Blue
But if you have a Crystalyte sensorless controller, and Crystalyte sensored HS3540 motor (extra 5 hall wire), then the phase wire will not match. There is long story about it, i don't want get into details for the moment. Now, you can also re-arrange phase wire to match, by simple using the jumper wire to correct the direction.
Ken
