Rocko19661
hi all i hope you can figure this out fast i sure you can i got 48vdc 2000 watt ebike hub motor kit i fried my old controller and i even replaced three mosfets i got it to hot fired the traces o well i got a new one and i confused on were brown yellow and Wight wire that says hall on it twister throttle has 6wires red black green i connected to control i hope there same colors needed to be others are the brown yellow and wight wire that say hall on it my control has throttle 1alam with 3wires learning set of weight wires 3speed switch with brown black blue rear set gray and black low brake Wight and black 1 hi brake yellow wand also how do i connect and use those 1 instrument green wire 1 purple lcd sceen i do not have yet but my throttle has green yellow and red la alarm power supply wrested and black standard hall wires crusde control set1 screw block set were i had to reverse blue and green to make wheel go forward and the block screw set with red and black power wires so were in the heck do i put brown yellow and Wight hall wire???
