TommyCat
Just in case you haven't seen this...
QSMOTOR Motor Manual
Careful with static electricity around these hall sensors.
What error code or number of flashes is this?
What are the hall sensors supply voltage readings, and do they remain that way for both sets after each of the hall sensor cable are connected? (I.G. 5vdc)
What are the halls signal voltage readings after each hall sensor is activated? (I.G. 0vdc)
But curious how you came to these conclusions...
Yellow hall sensor signal voltages.
5vdc coming from the controller.
6.1vdc when connected to the motor.
When connected and with the main phase wires disconnected... anything change?
Give ALL bench test voltages when available.
The readings are consistent with the secondary hall connector which for some reason causes a “lack voltage” error on the controller
This is correct for a 120-degree output sequence which your motor does use.The halls seem to be moving in a consistent pattern too with one on, then two, then one. Would this be correct for bipolar hall sensors?
Using a hall diagnostic tool I have been able to ascertain that the hall positions correspond with the phase colourings below:
1 blue
2 blue/yellow
3 blue/green
4 green/yellow
5 green
6 yellow
Did you check between cable wires and metal stator frame? Occasionally slightly pulling or moving the cables a bit whist testing?There are no shorts across any of the cables and the connectivity from the hub to the end connector all seems to be fine.
