Hi
I’ve got an Enduro ebike frame that I’ve been updating over the last couple of years. It’s now based around a Crystalyte TC3080 hub laced into a 24” rim.
I’ve just had to replace the battery which is now 20s7p 72v pack capable of 100A bursts using Samsung 30Q cells.
Controller is still the original Infineon 12 fet 4110 (from EM3EV) and it’s currently set up via a Cycle Analyst V3. I’ve played about the CA settings so it shouldn’t be limiting Amps in anyway.
I know the TC 3080 isn’t the most powerful of motors for this frame, but I’m not really up for changing the motor/wheel set up so I’m trying to make the most and max out the torque/top speed with the battery pack I’ve got.
I’ve not dug out the programming cable yet for the controller but it’s not getting anywhere near the performance out of the motor I believe is possible. I’m just about to take the CA out of the set up and run just with the throttle straight into the controller - will see if this improves matters, but I know I’ll be limited by the 12 fet controller here ultimately.
I’ve started to look at swapping the controller out and ditching the CA in the set up - I’d like to use the Sabvoton but have heard there can be problems with the Crystalyte.
Any one with the same motor or views on what controller I’d be best to use here?
