Samd
Nice work allex. I'd like to compare the output to the 29mm mxus. The clyte looks very well made.
Allex said:Thx Rix!
Yeah this clyte is actually incredible, if I would change anything it would be removing the unnecessary meat, the body is made out of extra thick aluminium. I bet you could shave of 0,5kg by doing this.
Still have not tried my sine-wave controller, no time!
I brought this TC connection info over from the (Sino/Silent Controller 24-120V/100A Program/GPS/Options-$199) thread in case someone with a TC needs help in getting it to synch up and run...the key is in the hall pattern...I first got it to run smooth backwards...then about 10 combos later smooth and steady forwards...I have a video to show operation and noise but can't get it to upload...
Final testing completed, and this controller from Powervelocity.com runs my Crystalyte TC3080 like a champ! Figuring out the Hall and Phase combinations was the killer...Crystalyte likes to make their colors in different order I guess, but after a bunch of trial and error and a huge amount of help from Powervelocity.com, it works great...Here's the winning combo for hooking this controller to a Crystalyte TC3080...FYI my Battery is 74v nominal (82v during testing) so the original voltage induced erratic operation problem of the TC3080 posed by HPC did not occur once the correct hall combo was applied...
Controller PHASE BLUE to Motor PHASE YELLOW
Controller PHASE GREEN to Motor PHASE BLUE
Controller PHASE YELLOW to Motor PHASE GREEN
Controller HALL BLUE to Motor HALL GREEN
Controller HALL GREEN to Motor HALL YELLOW
Controller HALL YELLOW to Motor HALL BLUE
Now to get the wheel laced so I can see what it will do in action...
GreyVlad said:What is the phase wires diameter and length?
Not with the Adapto, at least, not yet. Hey Allex, any progress?macribs said:Wonder if Allex ever got his motor running smoothly?
andrmorr said:UPDATE-
I've sucessfully ran my TC3080 on both a 12FET and 18 FET Sinewave controller from Powervelocity.com...
They run Smooth as silk & perfectly silent...The controllers are strong enough that I moved to the 12FET for space reasons in my full suspension frame and it handles everything my 74v 15Ah setup needs...
andrmorr said:74v 18650 GA batt built by Powervelocity.com
Clyte TC3080
12FET powervelocity.com controller
In the low speed it runs 20ish...In the middle speed setting this combo runs about 33mph with a 220lb rider and 26" wheels on flats and about 20-22 up the steep hills of Arlington VA & DC...In the hi-speed setting it will run close to 50mph but I haven't needed that often since #2 handles most anything...
There is no difference in perf of the 12FET vs the 18FET other than space since I don't push this combo anywhere near the upper limits of what the 12FET can handle...even after full power runs up the hills on the commute home it and the motor get warm but not hot...
I'm trying to figure out how to add .mov clips...I made a very short one but can't get it to show up yet...
Thats some seriously impressive copper fill.
I am using the same controller manufacturer that powervelocity is using, but using a different hardware spec and 3077 fets on the 12 FET version for better efficiency. I would be keen to try that as well.
Impressive conversion, I can see you put an emphasis on street riding. Nothing wrong with that. Would like to see some vids and fly bys.
andrmorr said:Thats some seriously impressive copper fill.
You say different hardware spec...How does your controller differ and what pros/cons are you trying to get/eliminate?
Samd said:[e]Thats some seriously impressive copper fill.
Clyte TC3080
Allex said:I have this particular motor for sale. Brand new, laced to a 24" ready with statorade inside. Never got my hands to build a bike with it!
Cant remember what I got it for, Rix, what is it worth?
