ebikefan
10 µW
- Joined
- Mar 23, 2011
- Messages
- 5
It's on clearance at Best Buy, new in the box. I tried searching for review or feedback on the bike here already and have read up on older models running SLA, but none on this bike specifically or with the new enlightened running Li-ion. Just want to get feedback on this bike.
This would be my first e-bike (with pedals), although I do have an eGo Vehicles motor scooter which is great, but sometimes I'd like to be able to pedal too. And of course I ride a regular bike too, but sometimes I want some help on those hills we have around here.
I'm willing to bet that I'll want to upgrade it after I've outgrown it, so any feedback on how upgradeable the chassis is would be great. I think its Aluminum so perhaps I'll want to change to a steel fork, or do a rear wheel brushless?
Thanks!
Mike
Here's some copied specs
MOTOR
Exclusive Alloy Shell DC Brushless Geared Hub Motor
BATTERY
Lithium-ion, Down Tube Concealed, 24V / 10Ah Pack, (7) 3.7V Rechargeable Cells Advanced BMS, Extra Energy, UL + CE Safety Tested
CHARGE SYSTEM
UL Listed Currie Smart Charger with LED Status Display
CONTROLLER
Exclusive Currie Electro-Driveâ„¢, 24 Volt Fully Potted with Power Gauge Function
TOP SPEED
Up to 15 mph / 24 km (Rider Weight, Rider Input and Terrain Contingent)
RANGE
Up to 23 - 30 Miles / 38 - 48 km with Normal Pedaling (Rider Weight, Rider Input and Terrain Contingent)
DRIVE
Exclusive Currie Geared Hub Motor, SRAM RD-X.7, Sram X.5 Shifter, 8-Speed Drivetrain
BRAKES
Tektro IO Disc Front and Pro Max TX-218 Linear Pull Rear; Tektro EL-340 Levers
WHEELS
Alex DM18 26" Double Wall Alloy Rims with Stainless Steel Spokes
TIRES
Currie 26†x 2.0â€, Slime Self-Sealing Flat Tire Prevention System
HANDLEBAR / STEM
Cruiser Bars with Dual Density Grips
FORKS
Alloy Suspension, Fender Eyelets
USER CONTROLS
Battery Gauge w/Adjustable Power Mode, Power On/Off Switch and Easy Access Charger Port
SADDLE
Velo Suspension Comfort and Micro-Adjust
Suspension Post
FRAME
Exclusive Currie Aluminum Design w/ TMM4 Sensor, Bottle Bosses (Mens Frame Only), Fender and Rack Mounts
CRANKS AND PEDALS
Alloy 44T Crankset w/Cartridge BB and Double Chainguard, Alloy Non-Slip Pedals
NET WEIGHT
51 lbs / 23 kg
RIDER AGE & WEIGHT LIMIT
Young Adult to Adult / Do Not Exceed 240 lbs / 109 kg
Thanks!
Mike
MOTOR
BATTERY
CHARGE SYSTEM
CONTROLLER
TOP SPEED
RANGE
DRIVE
BRAKES
WHEELS
TIRES
HANDLEBAR / STEM
FORKS
USER CONTROLS
SADDLE
Suspension Post
FRAME
CRANKS AND PEDALS
NET WEIGHT
51 lbs / 23 kg
