this is the pack that i am planning on running with, it is completely custom made to my specifications using high discharge cells from korea, if testing works out well it will become available for purchase. It will also be the battery i use for all future ready made eboards & DIY power kits.
this is a photo of the sample being made, and what it looks like finished, it has just been made & is in transit to me.
the cost inc charger for the KOREA cells battery pack is about 20% more than custom made lipos that i currently use, i will try to absorb this cost into my kit prices so that my customers get a superior battery system, I believe this type of battery is the future for eboard builders.
if i went with chinese brand 18650 cells it would actually be much cheaper than lipo but i have doubts about the quality & longevity. I may eventually test some chinese cells, but they don't have any high discharge rate 18650 available so would need to go 10S4P which would be much larger in weight/size.... however slightly more capacity with 325Wh (which is equal to 6S 15AH LIPO) that pack would offer peak discharge of about 60A... which would be good.. but it has 10 more cells.
this is the cost breakdown per Wh when comparing the cost increase from the cheapest option
chinese 18650 cost 100%
chinese LIPo cost 149%
Korean LG 18650 cost 191%
So I am going with a premium option because i really think battery performance is critical..I believe that the cheaper option will have too much voltage sag and won't be able to deliver the capacity i expect.. Im the guy that puts the high octane fuel in my car, not the cheap shit.
the specs of custom made LG18650 eboard battery:
> it is 10S3P
> 277.5Wh (this is greater power capacity than what you get from a 6S 12000Mah LIPO)
> Professionally built with spot welding of tabs to ensure reliability in high vibration environment
> pack made using LG He2 imported from KOREA, they are high discharge cells
DATA SHEET
> does 60 amp continuous discharge
> 80Amp BMS integrated.
> Built using 18650 battery holders to allow good heat dissipation & allow room for battery size fluctuations when temperature changes
> has panel mounted DC charge port
> Has common XT60 Plug for connecting to ESC.
