Russell and others, I've managed to get inside 3 of these motors today; 26"-24V-85mm front with disk, 26"-36V-100mm without disk and 20" 24V-100mm without disk. All these motors are the 108 type. Had to make up a special tool but got there in the end. Here are some pics to get you started. I don't have my camera so I used the webcam on my laptop.
The narrower, with disk front motor (85mm) has very different gears and the motor itself is physically smaller than the 100mm motor. The gears are partly helical on the 85mm motor and straight cut on the 100mm motor. Also compared the high speed motor for 20" rim (24V) and a 26" rim motor (36V) and they had identical gears. I have a rear 24V 26" rim, 100mm motor also. Will pull that apart and see if the gears differ on that model.
Will try to get some better pics up once I've got my camera back. Any more info required, just ask
