cbr shadow
Maybe someone can explain how the CA and the accessories cable coming off of it work..
I'm running 100v on the ebike right now, and I notice that the CA gets the full 100v out of its accessory cable to feed things like a headlight. The headlight would have to be able to accept 100v @ very low amps though, right? That's because the wires going to the CA are very thin, which is fine for high voltage if low current. So to run a headlight on my bike I'd either need to find one that accepts 100v low amps, or run a DC/DC convertor from the main power line, not from the CA.
Does this all sound right? What if instead of 100v I went with a 24v setup? Then the accessory cable would be running 24v at low amps which wouldn't be able to power much of anything, I'd think.
Thoughts? Am I way off base here?
