Cycle Analyst Current Throttle or Cruise Control
madro17
Hello,
unfortunately I have a problem in the implementation of the manual described in 9.3 Current throttle or cruise control function, in combination with my Cyclone 960W.
When I connect the circuit and the bike with voltage the CA always gives full throttle automatically. The different settings I've tried all, but no matter what is set, there is no response to the throttle grip. I have the circuit now already 2x rewired and i don't think there are bad solder joints. When I originally wired the throttle again it works as it should. The TH signal should arrive correct at the controller. If I change the AUX voltage on the CA, it also changes the speed of the motor. Even if Vi should not arrive, the CA should not automatically give full throttle, right? If you turn off the throttle, this signal also should be 0V?
Hope you can help me, I'm with my ideas at the end and unfortunately I can not even go without CA on the road :lol:
best Regards
Hi there,
did you do a search? Try this: http://www.google.ch/search?q=site%3Aendless-sphere.com+cycle+analist+current+throttle&sourceid=ie7&rls=com.microsoft:de-ch:IE-SearchBox&ie=&oe=&redir_esc=&ei=HB8_UMmjFK-a0QWxuoCoCQ
If you want more focussed help, try to describe exactly what you have done and what settings in the CA you have. From your very general description it is very difficult to determine whether you connected the wires correctly, or just have some incorrect settings in the CA.
Hi,
thanks for your answer!
Yes I´ve really done a lot of searching in the net, but in german forums i can´t find any help and maybe my english is too bad to find a correct thread in english.
I´m an electrician, so I´m really sure i´ve done the wirering correct. I've read the instructions several times, but I can´t find an answer for my problem. I´ve tried to set up a speed and a current limiter in the advanced menue- no reaction. The manual says if this is not activ, the CA would send a full throttle signal. It sounds like my problem, but i´ve tried both options current and speed.
All other values are default now. I´ve heard the Cyclone 960W should work with default setup, but I´ve also tried to change all other settings. The only thing i can do is to limit the full throttle signal but only if i limit the max output signal.
Hope someone can help me.
Kind regards
