zlatkomas05
- Joined
- Jun 13, 2022
- Messages
- 11
Hi there, i hope anyone can help me
, first I would like to thank you all in advance . I recently bought CA v3.0 and i done the connector and shunts work correctly and they show proper amps and watts. I have problem with throttle signal wire.
I tried with 1000om resistor and without but the hub won't start spinning...
It's my first CA experience and maybe I'm doing something wrong. If someone could help me, I really appreciate it.
What I checked and did:
The thumb throttle is connected directly to the CA, the throttle signal wire is on 6th pin on CA connector.
I enabled the throttle in CA's settings, pass through and tried limited and unlimited voltage on input and output.
When i measure with multimeter and disconnect the throttle signal wire from the main controller (6th pin)
And measure the voltage of the 6th pin of CA thr output on full throttle is 2.4v
But on the CA display input voltage its show 4.22v and output 4.22v but on the end of the 6th pin is 2.4v( i wonder why?
If i leave the throttle signal wire from the controller connected to the 6th pin of the CA the measurement with multimeter is resistance around 2000 ohm ( im not sure but i will recheck and update this parameter), no matter if i press full throttle or not and still on display is changing the input and output voltage but not on the ca throttle output 6th wire.
I change the throttle WOT and same max output 2.5 volt like on the pictures
Thank you in advance
