rightsaidmax
🧲 New user
Hi all,
Looked for similar threads for guidance but couldn't find anything..
Have built a cargo bike from scratch and was excited to install the Cycle analyst V3, with the E-rider torque sensing BB.
Running a:
Bafang G060 750W geared rear motor
JYT - YCSV controller
13s 1p EIG 20aH cell battery (thanks @jimbob01 )
Connected everything up, fired up the CA.
- Inputted the wheel size, the no. of poles (6? Think this is correct).
- Selected the E-rider as the type of PAS.
- Inputted the battery aH, string length and battery chemistry
I had to solder a different connector type for the throttle input on the CA, changing to the waterproof type.
The throttle looks to be working , I can see the graphic show the throttle status change on the main display.
The PAS seems to also be functioning as you can see the amount of HWatts or human watts in on the main display when you pedal.
However, the motor doesn't function at all from PAS or throttle input?!
I've taken the motor apart, checked continuity between the connector plug and all three phase wires and all hall sensors and all were healthy. Shorted the phase connections and the motor wouldn't turn and turned freely when they weren't shorted. So all seems to be ok?
The main display is showing something crazy like 140aH which doesn't make sense, the only thing I haven't done is input the rshunt value?
Can anyone help? Do you know if this controller and the CA are compatible?
Thanks in advance!
Running a:
Thanks in advance!
