VINTAGEBASS
Looking for some assistance as I am at my wits end! I have a cyclotricity 500 watt rear wheel kit with LCD at 36v. It has developed a fault where the battery power displayed on the LCD goes from full to empty in a blip if I start going uphill, the pedal assist works in short surges and it is throwing up error code 06. If I turn the battery on/off then it will work again temporarily but cuts out again. I have tested the battery across all cells and it is still showing 4.02 volts per cell and a total of 40.2 volts at the output and charge sockets, hence I think I can rule the battery out. I am not getting excessive resistance when turning the wheel so all wiring seems okay there. HELP!!
