hypersphere
I live in a hilly place. I commute to work via light rail. I have two kids. It rains a lot. My favorite grocery store is a 15% grade between me and there on an otherwise pleasant ride. My driveway is 20% grade. I'm fine with a top speed around 16 mph. I require torque sensing, love regenerative braking, and hate PAS. (PAS makes me lazy, torque forces me to exercise). I can comfortably pick up 50 pounds at most.
So I did what every normal person would do and built a spreadsheet of options which allows me to tweak mass and grade to see the effect of various bike + motor combinations. I calculated the force needed cannot be achieved by the front wheel alone even at 15% grade (even assuming 1.0 coefficient of friction) on most bikes (bakfiet -- yes). I have 68 combinations of bikes and motors.
I could get a Tern GSD. It's hard to maneuver it on the train and in/out the elevators. The hills will mean lots of brake usage. I have a similar bicycle and I've dropped it a couple times on the wet hill getting out of the house, and when it's 80 lbs + kids up high you can't stop it once it starts falling.
So after a lot of thinking, I'm going with a small bicycle with lots of torque plus a weatherproof trailer. I own a Dahon Mu P8 already and it can prove the concept; or maybe be good enough forever. The trailer can be parked at the kid's school if I'm going to work or it can go on the light rail like strollers can.
Without my requirements of both high grade and large mass, there would be a range of workable solutions. Alas, there is not.
I considered the Tern Vektron. It doesn't have enough torque to get out of my driveway at maximum load. I could add a second motor, which would give regenerative braking, but it'd put the weight over 50 lbs and either a separate battery pack or deal with a proprietary one. I do generally like that they come with lots of attachment points and for just kids or just groceries it could do it. Plus it's kinda cute.
I just learned about the Bike Friday Bosch-integrated bike with belt drive in development. Only downside is no regen but less chain maintenance. Could add an eZee front hub for regen but for just regen probably isn't worth it. Given the price... I'm going to try it with the Dahon first. But I'm going to keep thinking about it
Okay, so that gets me down to modifying the Dahon. It comes stock with a stock 52 tooth chainring and 32t largest cog. It's going to need me at the heaviest to get up the hill, so that leaves me with two feasible options for new front cranks: 64/104 BCD (3-speed mountain bike) or 130 BCD (2-speed road bike). A 64 BCD crank can get to 26T (or maybe less, but I don't need less); a 104BCD to 30T; and 130 BCD to 38T.
Some insightful person was, IIRC, writing a guide about hub motors and said something like "mid-drives can be under-powered because they always run at an efficient RPM. Hub drives must be powerful enough to keep you going fast enough they don't stay at an inefficient speed". Another insightful person, in a post about oil cooling motors IIRC, was dishing advice "if you're pushing your motor to the very limits, just pick a bigger, more appropriate motor". Prior to these revelations, I had been playing with the All-Axle, GMAC, and RH212 motors in the Grin motor simulator. I realized that, sure, the All-Axle does generate enough torque to keep me going around 4 mph up a 15% grade with 200 kg load, but it's turning 65% of its input power straight to heat. According to the simulators it won't quite overheat, but... while I'd rather my bike be 6 lbs lighter, it just needs to be below 50 lbs and the RH212 can both absorb more heat and is 10 points more efficient (33% more than All-Axle). And the GMAC 10T runs 2 mph faster than the RH212 and only 35% goes to heat. Between the motor simulator and trip simulator, I find the GMAC is going to spend most of its time in the 60-80°C range (despite the higher efficiency), while a RH212 will be 30-50°C. Would it be nice if someone made a sealed version of the GMAC that could be oil-cooled? Sure, but it can handle those temperatures, it'll save 6 lbs, and it'll use less battery.
You may have noticed I didn't choose a chainring BCD. Well, if I've chosen my motor as GMAC 10T and if I'm going to use a 48V battery with a Baserunner L10, then a cold controller would get me 8.7 mph. A 52T chainring with 32T rear at 80 RPM cadence is 7.2 mph. So I don't even need a two-speed road bike front; unless I let the controller get too hot. I have plenty of Al heatsink extrusion, so that should be preventable. But I'm solving this real time and now know I'm getting the erider 5-arm spider and not the 4-arm version, because it's a hub motor and I've got to keep the speed up. And if it broke down then I'm probably walking it up the hill (and making the kids walk too!) and on a flat I can still cycle it.
So I'm going to place an order for GMAC 10T + CA + baserunner L10 + erider 5-arm BB torque sensor + accessories, plus another for BB tools and such. Still need to pick out a BMS for 15S LiFePO4 and figure out where to buy some cells.
So there won't be much to add here until I order all those things and they get delivered.
