On a 3000W 45mm magnet height hub motor I added some Statorade. Now the magnets seem to rub on the stator.
I took a little video of it: https://files.fm/u/bnfztptnn
I marked the sidecovers before and installed them the same way like they were installed before.
I already tried using different sidecovers, replacing the bearings, removing shaft seals and adding/removing bearing spacers. Nothing helped.
I can only say for sure that it is not the windings rubbing on a sidecover, so it seems to be the magnets rubbing on the stator.
Without the wheel installed, when turning the axle with a 10mm wrench it is barely hearable when turning the axle very slowly, but clearly hearable when turning the axle faster.
Does anybody have an idea what could solve this?
