orange streak
Hello fellow e-bikers, & gear heads, & need advice please on a new type a freewheel sprocket design I'm making for mid drive ebikes, at least I've never seen it done. The idea is to make the left side driven wheel freewheel while not powered by motor, this also eliminates spinning chains and magnet drag, making it easier to peddle. One thing that's makes this project special is their is no thread on freewheels that strip the threads, but instead a short key shaft mounted freewheel that can take serious power.
A summary of how it goes together is a 2 1/2" bolt on adapter disk installs on the disk brake side. A key shaft 1.25" outer diameter keyway collar welded on to the disk. For a 3/8 (10mm) axle the shaft itself needs to be 1.25" OD with a 5/8 bore hole to slide over axle. A keyway freewheel that accommodates a sprocket & that is (high quality power rated), slides on shaft. The dropout needs space from the spinning shaft, so I guess a thin 1/2 inch tube goes in side of the shaft bore to back up on the hub & keep dropout clear.
I'd like to hear others opinions on the idea, & regenerative braking vs freewheeling for affecting better milage. If the parts can be found or machined, what key shaft freewheel can take up to 21,000 watts(28hp) for my project? What chain & sprocket should I go with, #35, or #219 go kart chain? I can get it all to fit with some slight widening of the dropouts with longer axle. My problem is I have a 9/16 (14mm) axle & larger sizing of components.
Plan to use with a mid drive QS 205 V3, 5 turn hub motor as a mid drive. My battery is 7kwh, 103.6v 68ah. Instead of having a top speed of 60+mph, I'll gear it for 42mph max for more torque. A lightweight mag wheel seems to take torque better than spokes. Need ideas & hope to get 300 close to 300 miles range on a charge.
