Destroyd regulator board?
gordone
My skills turn out to be bad when comes to solidering….
Nothing todo, just order a new kit of TSDZ2 and I have manu spare parts….?
I need to traine more I try to install the temp sensor again…
Properly good to for throotle version with 8 pin, then can I just splice the cables and not need to go down on the board itself.
Please see photo:
gordone said:
.... throotle version with 8 pin, then can I just splice the cables and not need to go down on the board itself.
It is also possible to buy another controllerboard only.
But if you buy an 8 pin version, the connector will not fit to the display.
If you buy a 8 pin Tsdz2 with throttle function, you can use the throttlewires for the temperature sensor, but not for throttle anymore.
Thank you,
I`m planning to use 860C/850C display anyway, so rewiring need to be done.
https://github.com/OpenSourceEBike/TSDZ2_wiki/wiki/Wire-860C-850C-to-TSDZ2
I was thinking I purchase a STDZ2 with throttle function, then must I need not test my soldering skills again,
but just splice the cables (I know I missing throttle function then)...
Agree?
https://www.ebay.com/itm/255155643421?mkevt=1&mkpid=0&emsid=e11051.m43.l1123&mkcid=7&ch=osgood&euid=892fbf443bc84226b48780d4b756b73c&bu=43891381419&osub=-1%7E1&crd=20211125180247&segname=11051&sojTags=ch%3Dch%2Cbu%3Dbu%2Cosub%3Dosub%2Ccrd%3Dcrd%2Csegname%3Dsegname%2Cchnl%3Dmkcid
I contacted these person, but he answear:
The motor you buy is not compatible with the throttle, unless you replace the controller and display.
There is not any reason that people are not selling TSDZ2 48v 750w with throttle function? they are not worse ? older ? or something...? It should be possible to find?
Maybe I need to train my solder skills and get better equipment....
have a great weekend everybody !
gordone said:
I was thinking I purchase a STDZ2 with throttle function, .....
Why do you go to ebay and not directly to PswPower?
imho they have a throttle version too
Hehe
My thinking is correct wire wise?
Go for these the?
48v 750w
8pin VLCD5
