MitchJi
https://electrek.co/2016/12/19/tesla-fire-powerpack-test-safety/
The use of lithium-ion battery cells in large energy storage applications is fairly new and the National Fire Protection Association (NFPA) wanted to know more about what would happen if it catches on fire.
Tesla built its Powerpack with safety first in mind and was willing to put its battery system to the test. The company teamed up with NFPA last year and gave them two Powerpacks to set on fire. We got a hold of their test results.
<Snip>
For the first test, NFPA tried to simulate what would happen if one or several cells within a single pod go into thermal runaway. Will the pod explode? Will it propagate to other pods? Will the entire Powerpack catch on fire or explode? Let’s find out.
They installed a heater cartridge inside one of the modules of a pod placed in the middle of a Tesla Powerpack.
They turned on the heater cartridge, which pushed the cooling system past its limit and while it could be detected that the cells/module was overheating, that wasn’t the goal of the test. They let it hit thermal runaway and the first “popping” sound of cells blowing up was heard after 12 minutes.
After just over half an hour, white smoke started to come out of the pack’s exhaust vent:
That’s gas created from the cells breaking down being evacuated.
The pops were still heard for about 15 more minutes and after it stopped, the smoke started subsiding over 45 minutes.
At 1h30 after the beginning of the test, the smoke stopped coming out of the vent:
Nothing exploded. How boring.
They learned from the test that not only the Powerpack didn’t explode or catch on fire, but the fire created by the heater cartridge didn’t propagate to other pods.
In fact, NFPA found that the 15 other pods were still functional:
“Following the test, it was determined that only one of the energy pods (the initiator pod) was damaged. The other 15 pods remained operational and had a full SOC. The energy pods were discharged and the Powerpack was recycled.”
That’s very good news. It means that a Powerpack cannot start a fire since if in the unlikely event that one or a few cells explode, it will be contained within the pod and it will not unleash the entire 100 kWh of energy capacity of the Powerpack.
