The Mighty Volt
Hi folks.
I dropped two 36v DeWalt drill-drivers off work bench and both are now displaying identical problems.
The motor spins perfectly but when the drill bit/screwdriver bit is depressed into the target surface, there is a bad grinding sound from inside the drill, similar to the sound when the gears are not meshing properly. The drill vibrates and makes a terrible sound. {there is a manual 3 speed setting on a DeWalt 36v drill, if you fall between settings the gears won't mesh and it grinds}
I understand that the most expensive and important part of this set-up are the 36v A123 batteries, but I like these drills, I don't want to have to toss them out.
Has anyone here come across this sort of problem before?
Thanks.
Thanks.
