Sacman
Does anyone else use dielectric grease on their connections like I do to ensure the connections are making solid contact? The first time I hooked up my Crystalyte kit I noticed some small spark or arching happening in the Anderson connectors between the controller and the battery sometimes when I gave throttle.
At first I stuck a small peices of foil in eact of the separate positive and negative connectors and the sparking stopped. I followed up with dielectric grease sparingly , again, to each separate connector. Definitely don't want to put too much in one side and have it oooze out into the other connector only to cause a small short between the two.
