arkmundi said:
Shinigaimi said:
Are there any fancy calculators or formulas that I can use to estimate the distance using a top speed?
Ya, its called a brain. :lol:
What a dick.
Feel free to ignore him shinigaimi,
arkmundi is new here, has almost no ebike experience, and none whatsoever with e-Moto's. We are all scratching our heads as to why he keeps posting "advice" here, but there you have it.
It looks like you are progressing nicely on your research, and you are correctly measuring in WH not AH, we appreciate people who do homework before asking questions.
WHM will vary widely with speed, weight, overall build efficiency, and riding style. I use 150-160whm on my Vectric E-Moto, but it is a heavy (500lb) bike and I drive 40-65mph on my commute.
There are a variety of calculators, but you would really need to quantify drag coefficeint and weight to get an accurate number, and you would have to have a good sense of your riding style which is pretty hard to do. Sadly, the best way to get a feel for this is practical application of ass to saddle. My advice for a new build would be to put as much battery as you can afford and comfortably/safely carry, I don't think I have ever wished I had less range. :lol:
Shinigaimi said:
Watts = Amps * Volts
Watts per mile = 125 (I read that a motorcycle uses about 100ish watts/mile)
Total Miles = Watts / Watts per mile
If any of these calculations are WRONG please let me know
First Battery pack 100AH @ 72v
Amps 100
Volts 72
Watts 7200
Watts per mile 125
Total Miles 57.6
Fully discharging your battery can impact it negatively, so I would also add DOD (Depth of Discharge) to your calculation. Conventional knowledge is to use 80% of a Lithium batteries capacity (80% DOD), and use 45% of a Lead-Acid to (45% DOD), instead of the 100% DOD you are using. In the example above, usable wh on a lithium pack
would be 5,760 not 7,200.
In addition... when I build an EV I spec a lithum pack to a 70% DOD, because batteries decrease in capacity as they age. In addition, be aware that the resisistance of your pack will impact the usable watts you get from it... With low-c/high resistance batteries like CALB, thundersky, and ping, a lot of energy will be converted to heat (10%? 20%), wheras a high-C/low resistance cell like a123 or Hobby King LiPo converts far less.
Anyhow, 60ah vs 100ah... For a given load, the more AH in the pack, the lower the 'c rate' of discharge. The lower the 'c rate' of the load, the less voltage drop. The less voltage drop, the less power wasted as heat, so you get a bit more WH from your pack. The lighter weight of the 60ah cell will give you slightly better WHM. If your motor is BLDC, the higher voltage will allow higher RPMs, not so for DC. That said, it is hard to envision a scenario where any of these differences will generate a significant delta. As others have said, the biggest difference is range... the 60ah will only take you 60% of the distance of the 100ah.
-JD
